- May 28, 2001
If the lash is that far out, it could well be that the crush sleeve has collapsed, and the pinion brgs are loose. Driven this way, the gear pattern WILL be toast.
I use the solid sleeve w/ shims to set brg loading.
Pull the d/s, grab the pinion yoke, and see if it moves in/out.
Check yoke fit at the trans output shaft.
