T
Tomas Del Maar
Guest
I have a customized chip which is my original factory stock chip that has been put on a burner or whatchyamacallit and altered by a local race shop that works on late model GM performance cars.
NOTE: This was back in May...The car ran awesome for 2 weeks...great throttle response, it felt like a different car and 15 psi boost with ZERO knock (room to go to 17psi)
However 2 weeks later the original MAF died....
Could it be possible that during the time of having the chip altered, that the MAF was bad OR going bad THUS AFFECTING the proper calibration of the chip?
Because I've tried rebuilt MAFs and GOOD used ones and it's never been the same since.
Running rich....slow to boost...sluggish....
I'm replacing my cat to a performance cat, and going to double check for exhaust leaks that MAY be causing the richness.
42 FP ---> 38 FP still gives me 850's mv and BLMs at a 145 peak while accelerating.
My boost is sllloowww to spool and instead of the set 15psi boost, it only hits 9 psi now...which is where I got my 914 millivolt reading with NO kNock (duh!) and 38 FP.
I'm trying to get my chip back to original stock factory specs. Whenever I get a hold of the guy who did it (local race shop).
I do have a chip coming from RONs CUSTOM AUTO in the mail...hopefully this week...he didn't say which he was sending but said he deals with Jay Carter and Red's.
So to sum it up...I have to get original chip set to factory specs, replace original cat with perf. cat and check for exhaust leaks.
Otherwise I've had it
