Propane on a GTP?
Tim Barnum
Will the propane effect the supercharger rotor? I've herd that alky will cause the teflon to come off if installed before the supercharger. Is there a way to install it after the supercharger on a 99 GTP? Let me know if you can help. Thanks Tim
I think propane would be the way to go on a GTP.
It would be easier to install, and does not have the corrosive effects of alcohol. Also it works better at lower boost levels like you would be using.
Does it spray as a liquid or is it dry? Would it be safe to run threw the supercharger? Thanks Tim
Dry
I dont see why it wouldnt work. Couple of guys are spraying propane through turbos with no problems.
How much is a kit? And will i need a throtle body spacer to install the nosle. I do run alky on my WE-4 and it works very well. I'll be a guinne pig for propane if know one has tryed it yet. Maybe it will act like a intercooler. Thanks Tim
It does act as an intercooler, which is propane's best feature. Jay's kit is about 600 bones, not cheap, but in the long run I think you will be very happy with the results, and your GTP buds will be drooling
One of the first "testers" for propane was a GTP, i dont think he has any problems to date.
Who was the tester? And how fast is his car running? I would like to use propane and not install a intercooler if the affects are close to one another. Thanks Tim
