Proper routing of Trans cooler lines
DeltaBravo
Retired U.S. Army/Navy
Hi all,
I've searched and searched...but haven't found the answer to my specific question.
Do the OE (hard lines) route below the passenger side motor mount or above?
This is the only picture I can find that refers to the routing of the transmission lines but it doesn't clearly display weather they are routed below or above the motor mount.
Thanks in advance,
Mine are off right now, but I'll set them up and snap a picture for you. Give me an hour or so.
Under the mount, following the oil pan rail.
That would be amazing and would help a lot. PO had some combinations of the original hardline and rubber hose spliced in a couple of areas...and they were routed below the engine mount. Just not sure how they came stock...since I'm using stock replacement hard lines from classic tubing.
There's also a metal tab at the back of the block, that keeps the lines away from the exhaust.
As Chuck stated above. The heat shield
