They say on the site that you must have stock ride height. I have eibach lowering springs in my car, does this mean I cant use the kit to convert to disc brakes in the back.
Originally posted by smallv6 They say on the site that you must have stock ride height. I have eibach lowering springs in my car, does this mean I cant use the kit to convert to disc brakes in the back.
I have the PST's on mine, and mine's lowered about 3/4".
BUT,
I found some shorter bleed screws, and I took a long punch and dimpled the frame a little for some extra clearance. Also Bilsteins and they help to limit axle travel better then other rears.
It will be real easy to push thru the brakes if your a drag racer. But for serious road work, their good. I have the 12"ers on front and they are a well balanced setup, once you gut the combination valve, but you have to watch the fluid level closely since if you have a leak you lose all your brakes.
