SignUp Now!Originally posted by Ted A.
Wastegate puck is leaking IMHO.
Nice times.
Originally posted by ijames
Grandnat, I think you have it diagnosed correctly. I have to admit I didn't think what the 127 mph meant when I first responded to your question - I just focused on the 20 psi boost. When the 54 first came out, Harry H. told me it was good for high 10's, and that he already had one customer running 10.6's (weight unspecified). Your 127 roughly equals 10.67 so flow/hp-wise I think you are done. Even if there's a little left, it's time to step up anyway. Please let us know when you do, and what boost/performance the new turbo gives you.
Originally posted by turbo2nr
Save your breath bro, I read your stuff already. I had a GN with Champion heads, blah, blah, blah. Even with a tiny 44 or a 49 turbo, 28psi is no problem. You have a problem with your car, or turbo control system. Have fun!
My latest GN, I have only had for four months. It has about 13,000 miles on it. I am a little shy about ripping apart the motor. I am very proud of 11.1 with just a turbo, and fuel, and PTE front.
Well, I'm sorry to have been a D!ck. But most people who read this will have a hard time believing 20-21 is all you got. See the other peoples posts. Even if your turbo is "maxed out", it still should be able to blow more boost than 20psi, even if it is just heated air. I, and others, think you have an exaust leak, poorly matched wastegate puck, leaking manifold, or a bad reading boost guage, or something. If you want to run faster, buying a bigger turbo is a no brainer! I'm doing it now as we speek. 127mph is pretty rocking for a PT54/TE-61 (same thing). Regardless of what boost you are running, I'd say thats the end of that turbo. So in your very first post, why did you stress the boost, then say it does not matter later? You should of just left that part out if it does not matter.
I'd like to see you run some 9s with a BIG turbo.![]()
