9" non lock up Art Carr 3200 stall. I doubt I will ever be going back to slick as I can't stand switching tires or the way the E/T streets drive so a little lag if any will be OK.
I am running a 67 large shaft turbo, 4" to 2.5" housing by Limit. I was going to buy from Precision but to many people on this board have had problems with warranty claims with them while no one has ever stated they had a problem with Limit. Limit states you don't need a large shaft in the 67 but I did anyway for durability. Precision has a 4" to 3" housing that might be a little better but Limit can aquire one for you.
I have 65 lb injectors but you can get away with 55 lb. People will say the turbo will outflow the injectors but 55's are good for a mid 10 or enough to blow your crank all over the road. Go larger if you plan on redoing the bottom end.
For tuning I am leaning toward the translator plus, extender chip and LS1 MAF. It depends on what type of sale they have. If not I will be going to a MaxEffort 16 position chip.
