SignUp Now!Originally posted by Ted A.
Girdle it this time?
Originally posted by turbonatr
cheeseburger,
Does your Duttweiler FM have 2.5" pipes? Wondering if it's the same FMIC I run in my street car.
Originally posted by JCotton
Nope........... nothing special about my "76" turbo, standard Turbonetics 76 wheel, with a tad larger than Q trim turbine wheel, probably about the size of the GTQ garret wheel. I think the larger than T series 4 bolt and comp housing are a huge benefit. Having effecient wheels that match well and using the correct housings along with a motor set up to match make a differance.
no cheater wheels necessary........
So how do you explain Garcia going 9.45 with a 109 or Bamford going 9.5 with a 109? They are both running over 140MPH with their 109s.Originally posted by Cheeseburger
I have taken the 109 block to its structural limits.
Oh, i was unaware that they are running factory unrebuilt bone stock shortblocks.
Ready to go, ship that sucker today.................. call me, is this Mike K... ?
Oh, i was unaware that you damaged a piston, rod or crankshaft. I thought you just hurt the block.Originally posted by Cheeseburger
Oh, i was unaware that you damaged a piston, rod or crankshaft. I thought you just hurt the block.![]()
