PTC 10" NLU, 3100 stall $300
Turbo6inKY
Short Guy
TurboBuick.Com Supporter!
As it says in the title. It's a PTC 10 inch non-lockup, 3100 stall. Fresh back from PTC after a complete service. Good as new. Tired of tripping over it.
$300 plus the ride. Hit me up!
And, I know pictures make everything better!
iSco5hsJl5DFFbHNHU4J-5b94nrch93MbrTYwpTT0-o0UC022GZ0GKN6djNP4-vSWz9SmFyxawseU7UmzWBi9ii8ZVKBT_fvwlWBTL7O_VbaGEJxpEEz36WfaNUg30YR0c285NktYL0=w2400
LOL...that makes me feel better. Although I did see a stat saying that the virus lived longer on cardboard than any other material!
Stamp on the case:
PTC10-700-27NLU-S200+
Yes, I ran this behind my 5857 with a 212/212 roller cam on a 4.1L.
I do not know if this is sprag or spragless. Hopefully the part number will tell you. I got it through Boost Crew, I didn't go into that detail when I bought it. I needed a 3100 stall 10", and they sold me this one. I raced it a couple years, then sent it back for a refurb and decided to go back to a lockup setup to try and cut the heat down when on track, so I put a lock-up ProTorque in the car and this has been sitting on the shelf since it came back from PTC.
Thanks it is a Sprag converter good for me. PTC asked if it has 21 B stamped on it?
thank you for your time
I'll have to check it in the morning for more stampings. It's raining. Again. I'm in for the night.
Ok, here are the rest of the numbers stamped on the this thing:
6175 B
65536 79262 84280 86235
"Converterman 01 11" (that one's laser etched, not stamped)
Thanks I’ll get back to PTC on Monday
It’s a good chance it’s a little tight for me
I was watching some of your video’s
What years did you run this converter?
