PTE 6776 Ball-Bearing turbo NEW
hwfstru
I have a new in the box PTE 6776 RSP Ball-Bearing turbo for sale.
A/R .70 Ported compressor housing
.63 PTE turbine housing
water cooled center section
This turbo is new with 0 miles and has never been installed.
$1200
What stall is recommended for this turbo and what size injectors are needed?
I would say 3200 or so on the convertor, but it is a ball-bearing so you may be able to run a 3000 stall. I would say atleast 55lb. or 60lb. minimum on the fuel injectors. This turbo is rated at 780 flywheel hp.
Turbo
Does this have the GT wheel? Can you send me pics? Do you have the Acuator? The water kit? Why didn't you use it?
Dave
This is not a GT series turbo, it doesn't have an actuator and I don't have the plumbing kit. You can get all the plumbing that you need to install this turbo at your local parts store, like NAPA. I decided not to use this turbo because I want something bigger. I have a PTE70 on the car now and I am thinking of going to a GT42R in the spring. Just changed my mind, my loss is your gain. This turbo is $1375 new from PTE, mine still has the warranty card.
I have 2 questions. Is this turbo sold yet? Is this turbo capable of putting ouyt more power than the regular LT or PT 67 I'd buy from red armstrong or pte? Thanx.
