Just about done installing PTE FMIC.  Having issues with driver's side.  Seems that the pipe to throttle body is too high and left of center, and the pipe to the driver's side at the IC is too low and right.  Is it possible that this is reversed from what it should be?  Doesn't seem like the pipe will make it around the radiator support if I flip the pipe around?  Ideas?  Anyone have installation pix they can post?  I can throw some pix up here later today if that will help.  thx in advance.  jn.
		 If you can imagine the core being wider by about 1/2", that would put the pipes in the correct position. Which is how it was with the old style core that they used in the beginning. What I did to make it work, was to run a longer hose from the long IC pipe to t-body and cut it too fit after I positioned the pipe as close as possible. I was also running the 45* bent pipe from the turbo to the IC for an external wastegate setup. Not the one with the 90* bend for stock style wastegate setups. Not the best fit in the world, but it worked. I'm sure Don did the same thing with his. This pipe design that goes from the IC to the T-body has not been changed since this IC first came out back in '95. But the core changed I believe back in 2002. I discovered the problem on my car back in 2003 when I purchased a new style core IC for my old grey car and fought with it forever. Just recently, someone else posted this exact same problem on here and Don replied to it. Here is a pic showing my old setup.
