I agree there needs to be more info though with installed pics in a GN. If I get mine installed before anyone else I will take pics. If I were selling I would have had these installed in a GN and taken pics.
I dont post pictures cause my car is in the shop but i also have a light in the center console and one in my hood when your creative and owe a gn we all know its expensive so these shouldn't be a problem..
I want to update my post to correct my initial observations. I spent more time with the lights today than I did yesterday. The lights appear much better than I initially thought with lights off, etc. I actually took some measurements and pictures. The first picture is the light 8" off the ground. The Grand National logo including the tip of the Power 6 is 11" long @ 8" install height. The second is @ 16" and the logo is 17" long. The third shows the angle of what I believe it will look like if mounted in the door without fabricating a method of mounting the light perpendicular to the ground. I find the angle acceptable if you can accept the angled circle, and very slightly different appearance of the word Grand and National. D
Personally I think I will be mounting them in the frame. I can easily mount them perpendicular to the ground, the light is brighter closer to the ground (although both are sweet looking), I don't have to worry about slamming the door messing up the light, and I want to put them on a switch an be seen even when the door is closed
I hope the guy selling these will become a site supporter although @ $28 a set he can't be making much. I also think he needs to learn to post more info about his products and use proper grammar to convey his thoughts. Some of your posts are down right difficult to understand because of misspelling, horrible grammar, etc. Proof reading helps a ton and you can edit your posts. I'm not trying to be a douchebag but you have a nice little product here. It needs to reflected in your posts.
