usetaboost
SAY CAR RAMROD!!
- May 4, 2005
ok first off I'm just kinda learning about transmissions. I've always been hesitant on doing much with them outside of a shift kit install. Before I get too far into this, the trans in question is a stock brf with the sk shift kit. After a frightening hard 2-3 slip the trans developed some noise a few days later. Thanks to dave husek, he helped me figure out what was causing the noise, which ended up being the pump. TOday I picked the trans up on end with the engine hoist and let the fluid drain from the tailshaft. There looks to be A LOT of I think is clutch material in the trans. POssibly some aluminum or metal shavings also. THe tailshaft had little to no in and out play but the input side seemed to have some slop. After pulling the filter out and the lu solenoid, I pulled the pump out and found this little booger laying underneath it.
