were you connected to the fast box , not just plugged up but connected as in able to see the various tables and parameters
when you say file was not there do you mean --you couldnt find it on your laptop-?
if so when you save it look to see what folder its saving it to ,
when you go to load it into ccomWP you may have to browse to see where it went , it should have gone to the GCT folder under whatever name you gave it
and on classic fast read datalogger is for getting a stored run out of an external data logger , its not for seeing the program tables and parameters
if you click help>contents.... at top of ccom wp it will bring up a full detailed instruction manual that you should be able to follow
