Pump Gas Set-up
snipersixx
Going to take car to track these week anyone care to take guess on what it'll run,
Car has ported champion iron heads and intake ported, 206 cam, 3.5dp, big front mount, 72lbs injectors, gtq70 turbo, 3400 stall converter, and 275 x60 m/t drag radials and boost set at 16lbs for pump gas?
id guess 12.0 at that boost without a trans brake
tires can handle a good launch but you probably wont get much boost under foot brake and your spoolup with the 70 will be slow
similar setup i ran 10.99 with a 1.55 60 at 18lbs but off tbrake open dump
with footbrake only managed 11.7s at same boost with 2.0 60's , could even get close to building boost before it pushed
I would guess at least 11.30s.
I ran low 7s at the 1/8 mile track with all that stuff and a t63.16# and 93 without any alcohol.
i would guess mid 11s or better, i ran 11.90s on 17 psi and pump gas(no alky) on my little 44 on nittos and 11.60 at 112 on slicks. But that was in great weather so who knows
at 16 psi you should do low 11s.
I have a 71GTQ and at 18 psi it does 6.9s @ 101+ MPH which for me = 10.70-10.80s
