Just pulled my fuel pump after cut out & quit issue and was hoping someone might recognize the numbers stamped on it: 6443572 on top line 3107-107 on bottom line. Car quit and would not pump fuel under all trials then fired next morn then nothing then off & on......................(all relays & hot wire check out)
I was told and given copy of repair order that a new tank and Red's xp were done in late 2011, tank is new just confirming pump if possible.
After tear down discovered some poor wire work and old send unit so I will put this pump back in, did a 10 gal 10 min steady test and pump seemed fine.
Any thoughts or ideas are appreciated.
