Pump rebuild question
tracer
INOV8
I have one of Razor's old kits (old!). Worked beautifully until the pumped packed it in this week. Unfortunately it is the old style pump with the lines coming in up top. Does anyone know if it is possible to rebuild this unit?
Since the alcohol ran down through the inside of the motor, the simple answer is non-repairable.
Motor parts(brushes, armatures, bearings, retainers, bushings) are simply no longer available. The upper part of the pump is, thats why the cover went on to keep liquids from getting into the motor. This requires motors to be installed head down, so if a leak happened, would not go through motor killing it. Been like this since 2006...
Anyone else can chime in..
