Feb 20, 2013 #1 hensleyt Well-Known Member Joined Feb 20, 2008 Messages 1,555 If I get a set of T&D rockers,can I use my same pushrods
Feb 20, 2013 #2 N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Messages 9,208 Yes, you should be able to use the same pushrods. If these are iron heads, you may have to clearance the stands, or the rockers may interfere with them.
Feb 21, 2013 #3 hensleyt Well-Known Member Joined Feb 20, 2008 Messages 1,555 I set then up on the mill and cup them, Id like to see some numbers on depth and width. I used a 1/2 ball end mill went 3/8 down and 5/8 wide
