Pushrods.......
Nope.Different heads and different valve train.If replacing...two options.
Johns performance sells adjustable type PR's.Call him and he'll give you the low down on the issue.
I'm currently working on a roller rocker/guide plate/screw in stud thing.I wont have all the info for a little while.But will have it eventually.Probably be the first of the year.I'm planning on using a higher ratio rocker to increase the stock cams lift.:D
Julio
