Brand new, installed and ran for about 30 miles. Enough to drive it back from my friends shop and around the neighborhood doing some troubleshooting.
I welded the mufflers to the y pipe and put v-bands on the tailpipes. I also built some mounts for the mufflers with rubber hangers and brackets that bolt to the upper control arm cross member. Everything is tig welded. As you can see, it's been used so little, there is zero discoloration. The stickers are still on the tailpipes. The cutout is not included.
Will sell for $350. Compare to $420 from kirban and $80 in v-bands plus welding and mount fabrication. I don't want to bother with shipping this. It would have to be palletized and that would make it not worthwhile. I will meet within a reasonable distance from Middle TN or I'll bring it to the GS nationals in a month.
The V-band clamp is just resting on the muffler side. The tubes still slide inside of each other to self locate to help them seal.
