I used to run the GM F body 34mm hollow sway bar with my Precision SLIC.
Due to its larger diameter , but mostly the curving shape of the bar vs the stock seat bar, I needed to notch my aluminum shroud & make up 2 new aluminum plates to close in the shroud.
The other thing I had to do was install a washer behind the passenger side intercooler support bracket . Needed to do this to kick out the intercooler a tad at the bottom in order for the sway bars articulation to be able to clear the meter cooler shroud. Additionally this made needing to run a longer throttle body to intercooler connecting hose as it pulled it further away. Think I used a 3” long silicone hose.
Was a pain in the arse dealing with it , got so tired of it that I put the stick front sway bar back on the car & returned the stock intercooler shroud side plates back on
