forcefed3.8's
Buckeye Bullet
- May 26, 2002
245" Weber stroker girdled with stock caps
224 billet roller
old casting GN1's ported by myself
1.65 T&D's
cometic headgaskets
GTQ76 turbo
home ported stock intake
stock throttlebody, Hemco upper
Cotton's front mount
Pete Tomka 4" intake with 4" drop in Z06 sensor
95lbs injectors
ATR double pumper
3.5" TH DP and single exhaust
stock headers cut open and ported by myself
0 pump 5 disc Vigilante 3000 stall
Full billet Janis trans
Eaton Posi, 30 spline Moser axles, C-clip eliminators
21psi 20deg timing 8psi launch shifting at 5400
1.48 60'
6.52@106 1/8
10.20@134 1/4
The car went 6.49@109 at 25psi running dangerously lean before. It was running lean here as well from a user problem with the translator:redface:. I got the translator and wideband tracking figured out, hopefully I can get one more trip with more boost before the snow flies. It is impossible to tune on the street, not to mention unsafe. Traffic and turns come up in a hurry.
224 billet roller
1.65 T&D's
cometic headgaskets
GTQ76 turbo
95lbs injectors
ATR double pumper
1.48 60'
6.52@106 1/8
10.20@134 1/4
