Question about brake upgrade
SillyCBR
Previous owner did a bang up job of switching over to vacuum brakes. He is drawing the vacuum from the passenger side pcv. I just ordered the TTA vacuum block to correct that problem. Now, what do I connect to the passenger side pcv when I when I connect the vacuum to the tta block. Thanks in advance.
pcv hookup
did he "T" into the pcv? If he did just remove the T and get a new hose to replace it. If not, one end goes in the manifold, the other on the biggest hard vac line coming from the vac block
