my85grandnation
85 Triple Threat
- Mar 12, 2004
I have always seen that you are supposed to run rear GTA wheels up front on GN's with a spacer and longer studs. If they will work that way up front couldnt you just add a spacer and have longer studs and run them on the rear of your GN, or will they have clearance issues no matter what you try? I have some rears that are up front on my car and when I turn they rub slightly even with the spacer. Maybe the tires are just too wide? I think they are P245/50R16's. Any help is greatly appreciated. Thanks
