cottonpicker14
 - Feb 17, 2005
I understand that at WOT the reading should be 255.  I thought that there was a way to test the reading with the key in the on postion and not running, that you push the accelertor to the floor to see if it reads 255.  Is that correct ?  If so, I tried that and the scanmaster on the reading on the AF did not change.  So, will the reading of 255 only be with under WOT and cant be tested with just the ignition turned to on ?  Hope I made sense here.
