Bought a mechanical boost gauge and one of these weekends will get it installed. I prepped the end of the tube to tee into the existing vac line for the factory boost gauge (analog dash). After installing the vacuum connector on the end of the supplied nylon tubing and heat-shrinking it, I sucked some air through the line to be sure I didn't melt the nylon tubing. It was clear, but I noticed that it was more difficult to move the air through a longer piece of the tubing than through a shorter piece (makes perfect sense).
I'll obviously keep the length as minimal as possible, but won't this have an effect on how the boost gauge reads? My physics background tells me that one of two things could happen.
1) The boost gauge will read a little less boost than is actually being generated, or
2) The boost gauge will be slower to REACT to the changes in boost level.
Is my thinking off on this, or is there not enough difference to concern myself with it?
