Question about setup....
Beast_TR
Ok I just bought a 87 GN with some work done. I have a 208/208 cam, 72# injectors, race and street chips, stock turbo, stock maf. I know the injectors are way too big but I do plan on running a TA60 turbo very soon and wonder if I could get away with this setup for a short period? New to the whole Buick world. I also have a port and polish intake manifold/plenum, 62mm TB, and adjustable regulator. Thanks for the help!
this may help but I know that a big turbo and stock injectors will run. not sure about the other way around.
Injectors are never to big...Don't worry about it...It about this all of the guys running those big 72 pounders, are pulling the same amount of air at idle as you are, if they aren't to big for them them they alright for you.
If I were you, I'd have a chip burnt for it if you're going to leave it like this. Evidently, someone had a bigger turbo on there at one time.
yeah with big injectors a good chip VERY necesssary.
That makes sense. As long as the chip is matched for the injectors it really wouldn't make a difference at low air flow levels.
