Question About Using Casper's CCCI Ignition Simulator
brn agn
What do you guys look for when you are testing an ignition module/coil pak using this tool? Inconsistent spark, no spark, color of the spark? Thanks!
Consistent spark accross all 3 coil sets when you crank the knob up to a simulated 6K rpm. IE all the way up.
A bad pair will look weak, you can't miss it the spark will just start to go away.
Fun tool always draws a crowd. :D
Good sound effects too. ;)
I got mine in today...put it on the car just to check it out. All of the sparks looked similar, especially at the higher RPM's.
I thought it was pretty neat to watch too! I bet my Electrical Engineering friends from college would get a kick out of it!
Thanks for the quick reply!
