Question for converted 84/5s
TType85
TurboBuick.Com Supporter!
What did you do when you swapped the 86/7 setup in for the fuel lines?
Where did you put the fuel filter?
:D im not telling :D
nah really i got a stock replacement fuel injection filter for a ford truck...they have long nipples on each end and they're kinda big.
i've got mine above the rear axle were the rubber lines from the tank hook to the steel lines.
on these filters there's a ridge the the ford clips go behind so i shoved the hoses up over the ridges and put a clamp on either side of the ridge so it for sure wont go nowhere
on thing to do if you use this filter is take a flat head screwdriver and ream the inlet and outlet open...you'll see what im talking about once you look at one ...the very ends kinda roll in so i open them up to remove any restriction.
from the frame to motor i used 86-87 fuel lines.
ok im tired ....later
