Question For Razor
SCOOBY DOO
BASED CANADIAN PATRIOT!!
At what boost pressure do you have the default setting starting to spray alky? TIA
I believe it is 6 lbs. of boost. Due to 'variables' with each car 5 or 7 lbs. of boost to start spraying is not uncommon. Light should change from red to green when pump pressure hits 50psi. I'm interested in what Razor has to say as he is 'THE MAN'! :)
2.2 volts DC of the green wire = approx 6-7 PSI boost. Depending on altitude, map sensor calibration, etc.
The 2.2 is physical setting of the Turnon inside the PAC controller for the Buick app.
Thanks so much.
