I have a short in the electical system somewhere. It seems to be capacitive in that it usually hangs around 11 ohms. However it drops to 2 ohms and occasionally will up to around 100 ohms for couple seconds then back to around 11. This is with the battery disconnected and testing across teh 2 terminal cables. I took all leads coming off the starter post where the battery connects and as memory serves, the short was on the single small wire, not the ring with 2 wires on it. I pulled all the fuses out of the fuse box and no change, so it seems the shorted wire off the starter doesn't go to the fusebox at all, but somewhere else. Anyone have any ideas where that wire goes to if not the fusebox? This is driving me crazy killing batteries in 2 weeks.
