Question for those with 84/85 GN Hydroboost
GNRick
Retired member
I'm trying to install a Hydratech HB on my 87 GN. I bought the hoses for a 84/85 GN from Rockauto. It looks pretty straight forward to connect the hose from the HB to the gear box. Can someone post pics of the hose from the hydroboost to the power steering pump? I know they didn't change the pump from the 84/85 to the 86/87. Inlet to the pump is on top of the pump. Maybe a short description of how the hose is routed would be nice, too. Thanks!
Kinda hard to get the camera down there. The line off the pump has a 90* bend. The line goes back behind the accessory bracket then down around the bottom of the pump.
Thanks Rick. I know you have an 86/87 with custom lines. I was just wondering how the factory routed the line. I may still be coming up Sat. to look at your installation if that is ok. I'll call you first.
