Just put new springs in the car all the way around. The car now has a 5/8 - 3/4 inch lean, with the passenger side being lower. I tried to get the front springs to line up with the first hole in the rear of the lower control arm. There are two sight holes, and I know from experience with my "A" body that you have to be able to see the beginnning of the coil in that sight hole for the spring to be set up properly. Did I do it right? Should they be lined up with the second hole? I took the measurements from the frame to the ground, so I'm sure it's not the body bushings. What about the rear springs. Any tips on making sure they're aligned right?
