Question on down-pipes. One or two piece?
mrbuyit
Hello board. I have a 1987 GN with 31k that I am goign to add a few mild upgrades to this spring. One of those upgrades is a new, 3" SS down-pipe. I have seen that there are one and two piece designs. Not sure which to go with and/or what are the advantages/dis-advantages of each?
I appreciate any feedback.
Jeff
Depending on you goals, a 3" Terry houston DP is gonna be your best bet. Or you can go to a 3.5". I would go with a one peice, I'm not familiar with the "2" peice.
stay away from the 2 piece since its a stock style replacement downpipe...id go with a 3" from RJC they have the best fitting downpipes out right now
The 2 piece uses the factory elbow. What you want is a one piece that replaces that elbow and pipe. I went with a TA perf 3" and I couldn't be happier. I really believe that the stock downpipe was holding me back a ton. Car just feels so much stronger now.
Oh great! Just when I thought I was done conjuring up more fabricating projects,your post pops up!!....Nice stuff BTW!:biggrin:
when is it suggested to get an upgraded downpipe? In other words what are the limits to the stock unit, and what kind of gains could I see considering the mods in my sig. thanks.
The biggest downfall of the stock DP is the 90* coming out of the exhaust housing.
A TH style DP helps regards of performance level.
Billy T.
gnxtc2@aol.com
Buy the 1-piece....do it right the first time and be done with it! I have the 2 piece, because I didn't know better. Was a pain to seal. I don't like the way it looks(having an exhaust clamp where they meet)...plus its pretty cheesy where it meets the factory exhaust elbow. I had to use hi-temp silicone(which will probably burn off in the near future).
This spring I am going to buy the RJC one piece unit.
