question on Q-boost MBV........
NCC1701
Hello,
Is the stock vacuum line with the restrictor used with the MBV, or is it replaced with just vacuum lines?
TIA:D
Hello,
TIA:D
Since your going tuner style ditch the "y" and associated vac lines. Use the MBC between the single vac line you will need between the turbo boost output and the wastegate diaphram...
