gn87man
- Apr 18, 2016
Has anyone ever seen a block become extremely brittle and flake off into a powder while attempting to machine the block?
Here is my situation...
My engine builder informed me that the block has been dipped in the hot tank and into the caustic solution bath.
The engine was also pressure blasted with high pressure air.
The problem is not rust. It seems to be that the block is basically corroded to the point that it is disintegrating.
In the pictures, on the bottom of the block, where the oil pan gasket is attached, it looks as if part of the oil pan gasket needs to be removed. However, that is not the case. This is the actual block flaking off. The metal is physically flaking off. This is shown in several areas of the block. Especially on the top side of the block on the slanted wall that comes down to the valve ports. The engine builder took a regular screwdriver and gently tapped it against this top face of the block and the metal just started flaking off into powder. It is the strangest thing I have ever seen.
These imperfections were unable to be detected until after the block was hot tanked and dipped in the caustic solution bath and blasted with high pressure air.
I have no idea what might have caused the issue.
Please let me know if anyone has ever experienced these issues with a block. If so, what was the main cause?
Could it possibly be caused by the block sitting in storage, near the coast, for several years (exposed to a saltwater environment)?
Or possibly the block being left in the caustic solution bath or hot tank for too long?
Please see attached pictures.
Thank you!
Thank you!
