darkred87T
- Oct 27, 2003
Sorry, kind of long. I took the Regal out the other day to get an estimate on body work and paint. Anyhow, the tempurature that day was just around freezing. I had a full tank of 94 octane and the PAc was topped off with Methanol. I went to get on it after it was warmed up and the knock guage shoots into the red immediatley. I look down and the red LED on the PAC unit is off so thinking I left it off, I went to turn the knob and it was already in the on position. It turns out I blew a fuse in the unit itself. O.K.
, so I just repalced the fuse and everything seemed fine. I took the car out again tonight, (again the Temps were around freezing) and noticed the lights were comming on but I had a lot of knock again. At a stoplight light, I pushed the test button and when this usually almost stalls the car, it had no effect. I drove the car to my Parents house and removed the inlet tube with the line and nozzel still hooked up. I called my dad to come out and push the test button while I looked in to the tube. After him pushing the button a couple of times, it finally sprayed. Does Methanol freeze? I don't know much about Methanol. Maybe I should learn more about it before secrewing around?
