I've went the Cryo'd & Coating path...
Everything except the crank in the rotating assembly and couldn't see a reason for doing the intake. Complete heads, pistons & pins, valves and springs, rocker assembly, cam, push rods, rollers, bearings, turbo and fasteners.
Turbo was disambled for cryo treatment and drop shipped to Calico.
Heads, valves, pistons & pins, rings, springs and bearings were coated @ Calico Coatings (Jerry Ehlert). I did not coat the crank since IMO windage isn't a factor until you get past alot more rpm than these will be turning. As soon as I'm finished with the exhaust system, it will get coated @
www.Calicocoatings.com.
If you need bearings check with Jerry, he may have them on the shelf or if he doesn't can most likely get them for you cheaper than you will find them and save you some expense.
Note: use moly base coating on bearings with a forged or billet piece.
(Teflon on a cast crank ie. stock piece)
Malory metal will break the crank if it is in place, balance the crank after the cryo process and it would not hurt a thing to get it coated. It's only money.
Cryo Treatment
Bob Reed
www.300below.com
Decatur, Ill
Gary
