check the link in my sig for my homepage. I just started tearing down the motor for the removal a few weeks ago. It is not too hard, but you gotta be familular with the wires. Go and buy paper sticky lables and lable every single hose and wire before you pull it. Go from one side of the car, around the front and on to the otherside, not missing anything. After that, disconnect the hoses and throttle cable to the TB, Remove the up-pipe, and diconnect the DP and crossover-unscrew the three mounting bolts to the turbo and pull the whole unit out with the TB still attached. That will give you plenty of room to get all the wires labled and removable. Of course, diconnect the tranny when you pull the crossover down. When you get the turbo off, take the DP off of the cat and then get ready for a ton of wires!
Just make sure you lable, lable, lable. You will regret ever touching a wire if it is not labled. Hoses are the same way! Good luck, let us know how it goes!
John
