turbojimmy
Supporting Member
- May 26, 2001
How's your WBO2 location working out? Looks like it's pointing at the torque converter area. Where did you feed the cable into the cabin?
The location seems to be good. I wanted to get it far enough downstream that it's not too hot but not too close to the test pipe in case I develop a leak there and/or uncap it. I run the cable through the same hole on the driver's side that everything else does (I think it's the one that the throttle cable goes through?). There's plenty of slack on the LC1 cable to run it to the LM1.
Top Speed said:Jim, that looks great. I want to do the same thing!
Thanks! It was a lot of work to put together but worth the effort.
Jim
