Rodney87GN
- Feb 1, 2004
A few days ago I blew the passenger side head gasket. The driver's side appears to be ok. My question is...assuming the drivers side head gasket is indeed fine, should I replace it anyway? Sorry if it sounds stupid...but I'm thinking that since I have the motor torn down that far anyway, it's not much more to remove the other head to replace the gasket and start "fresh".
On the other hand, I'm also thinking "if it aint broke don't fix it.":biggrin:
One more thing...I think I got lucky with the way the gasket blew. The fire ring on the #4 cylinder blew outward (towards the header). So no oil or water got mixed together (I run straight water and RMI). When it blew, no smoke was coming out the exhaust, oil pressure was still normal, and it didn't overheat. It just sounded like a huge, nasty exhaust leak....
So should I still drop the oil pan and inspect the bearings, or clean out the oil pickup? I'm assuming I shouldn't have to since none of that crap got circulated in the motor. I was planning on just changing the oil and filter a couple of times to flush it. What do you guys think?
