quick exhuast question
87 gnash
ready to purchase kirban 3 inch down and 3inch replacement cat... i am then hooking it up to the ATR 3 inch system..
help me out... is this a good idea... or will i run into any problems
I doubt you will gain much with Kirban's pipe and a stock elbow...particularly if you leave the cat on.......spend your $$ on a ported elbow and lose the cat.....(you can put it back on for emissions testing)
or get a Terry Houston type downpipe which eliminates the stock elbow altogether and it comes with a "test" pipe to eliminate the cat
thanks woody
i just ordered the the terry houston 3 inch down pipe with cut out... i appreciate the help here.. you just set me straight...
i am now going for the atr exhuast.... which one do you recommend of the two 3 inch systems?
