Quick question about aluminum heads
So instead of running the 6262 up into the low 30's you would run a slightly larger turbo? I was hoping more for the 6-650 range with the updated short block.
It would depend on a lot of things. If I was wanting to make power and wasn't too concerned with spoolup I'd run a larger turbine for sure and the cam and CR strategy would change a lot. Also the fuel being used would be considered.
