turbo96max
- Jun 6, 2007
PowerMaster Diagnostics
read at the above link that increased pedal travel can be due to air sucking into proportioning valve. but theres a different diagnostic for a pump staying on.
my pedal goes all the way down, like a bad master. not hard. the brake light is on constant and so is the pump. only reason i ask is bc i found a new spare accumulator in my parts closet, and im not sure if i want to try it out, or just switch over to the vac brakes.
bc if its a leaky proportioning valve then ill still have an issue with the vac setup as well???
and im not sure if i should just sell the spare accumulator since im not sure this is something i can try out and remove??
