I have a FAST XFI. On the harness there is a fuel pump wire that is supposed to be connected to the "negative" side of a relay used to energize the pump. My question is...where do I wire the other side of the relay? Do I go to IGN in the fuse box or do I just ground it? I already have the two power wires of the relay hooked up. Thanks.
Addition: Basically I want to know is the FAST fuel pump wire supplying the 12v to the relay or do I get the 12V from the fusebox/wire harness in trunk?
