SignUp Now!Is it a Champion stock ported or a Champion race (off-center) intake?
Both will function on stock iron heads.
I think others will tell you it's overkill if not running quicker than 9.50's?
What are your goals?
Yea I'd put that money towards a good set of aluminum heads. You have a good bottom end?
There is no gain for you to use the race intake and like turbo clam stated it is for 9.5 and faster applications. By the time you get the intake fuel rails and deal with the wiper coil pack interferance you will have close to a grand tied up in it. Fyi I am running upper 9,s with a ported stocker. You could call and state your dilemma to the the various vendors and see if they are willing to work on price. For a large order they miggkt work with you. Best of luck brother.
Awesome sounds like you are on the right path have fun some with your build.I'm not going to be stubborn and run an intake that isn't necessary. If one came up used for a great price, maybe, but paying MSRP for bragging rights isn't really what I'm after. That money can now go toward my fuel system
Also, Full Throttle ended up having the best prices on what I need after all. I found the Eagle crank for $499 and the Molnar rods for $519. I'm holding off on pistons until I can check the condition of my cylinder walls and get a definite idea of my deck height.
