TurboRussty
- Oct 15, 2002
what is the fuel pressure suposed to be at when the car is in idle with the vacum line off.could somebody please help me with this info...
SignUp Now!Originally posted by TurboRussty
hey bryan whats up finally someone who can give me some insight on this problem. the car runs the 840-870's at wot at part throttle the numbers are good.
i run 93 octane so far chevron w/techron my partner told me to run some xeylene in the sysyem and then check for knock he said to add only a gallon will this help any.
i have nit changed the o2 but it appears to be changed the cable and the body of the sensor looks brand new the only thing that i did notice is that it has only one cable could this be a problem. i know that my friend is running either a 3-4 cable sensor does this have anything to do with it.
the atr chip is agressive for pump gas, once you are running higher octane, you might actually like that chip. adjusting your tv cable will make the shifts firm or soft-Originally posted by TurboRussty
for sure the thrasher is coming hopefully that chip will not have the kickdowns set so hard like this atr chip does. i think it is just to plain aggressive hopefully the thrasher chip will adjust this.
also i have noticed that when i get off the gas at any mph the car drops rpm's almost to turn off but it does not. but it does it everytime i let off the gas.
when i get on the gas sometimes i have a slight delay before the car takes off almost a hesistation but very fast. i noticed then when the fuel pressure was up to about 44-45 psi then the car did not do it anymore but when i brought it back down to anything below 42 psi then the car started doing it again.
whats the deal with my car i want it to be streetable yet practical at least more practical then my impy ss i mean i used to get 350 to the tank in my impy ss and its v8....
also where is that fuel pump check valve located at so that i can see if there is even one on my car.and the guage holds and reads the same when the car is turned off it holds the same amount of pressure when on as it is turned off. so i guess i do not have a leaky injector... right.....
that atr chip has alot of timing, try the thrasher chip, you "should" be able to run 17psi of boost all day long with it, you need to purchase a race jace power plate, do a search or post in the forum about what the plate does,.... it really worksOriginally posted by TurboRussty
i really hope the thrasher chip helps out on the scanmaster me and my friend turbojorge took the car up after 3rd gear to see if i was registering any knock then and i was getting 3-4 degress of knock at WOT this is with the F/P set at 42-43 psi and the boost spiking to 15 psi then holding steady at 14 psi the whole way.
also do those thrasher chips come programmed for a 160 t-stat....i wanted to know cause i put a 160 t-stat in my car and it was still running at 187-191 degrees.....
bryan let me know what you think.
dont adjust the tv cable to the point of where it isnt taunt-Originally posted by TurboRussty
also the TV cable as you listed is adjusted for a softer shift, before i even started working on the car it was to tight everytime the car shifted 2nd gear it would chirp them stupidly. so i kep backing the cable out until it felt sort of normal and the cable hardly has any tension on it whatsoever. i just do not like the way it feels when it kicks down it just feels like it is going to do a beatin on my driveline.....
how do you set the iac?
