Jim, I believe that Direct Scan does, in fact, give the actual commanded injector pulsewdith. It is not a calculated number like the hp/tq values, or the a/f ratio value. As for the a/f ratio value, it would be about right (ballpark anyway) if the MAF could read over 255 gm/sec. That's the big problem with that calculated number, at WOT the A part of the A/F gets stuck at 255. Hmmm... what kind of a/f ratios come up on DS when using a Translator with Extender chip? Just curious, if anyone wants to share.
Anyway, I know this comes up once in a while, and I emailed Kent a while back about it. Here's his response:
Date: Mon, 9 Jul 2001 08:08:14 -0500
Howdy John,
If I remember correctly, the injector pw is taken directly from the ECM's
working RAM. I believe that the ECM takes this value and applies it
directly to the injectors. I have to use an equation to convert the basic
hex number into the inj. pw number. From the information that I have, the
correct equation was used.
An interesting tid bit is that the chip controls the injector pw to a great
extent. In other words, the chips programming and data tables can actually
try to command a very large pw (i.e.: greater than 100%). DS displays a
dotted line in the graphic displays to indicate to the user what the
theoretical max pw is. As you can probably guess, the theoretical max is
simply based on the current engine RPM. Afterall, the intake valve can only
be open for so long at a specific RPM. That time is the max that the
injectors should be on since any more would cause the fuel to "puddle" up on
the valve and possibly even evaporate due to the heat.
I don't see any reason to not trust the number. There was some confusion
very early (i.e.: v1.0 s/w) as to how accurate the number was. However,
after conferring with multiple sources, the current displayed value should
be accurate.
Thanks,
Kent Chu
You could also review one of our threads from way on back,
http://www.turbobuick.com/forums/showthread.php?threadid=5187&referrerid=908
Todd K mentioned in there that his homebuilt device that measured actual inj pw flanged up pretty well with what a scan tool would spit out.
Now, if DS is saying your car is using 80% DC, then I would believe it. I would guess that in that particular situation you would be pretty rich if you don't have the airflow to match it, or that your engine is particularly inefficient if you don't get a reasonable amount of hp out of it. Just saying that you could be throwing a lot of fuel at it and not making big hp for a number of reasons, I don't think this is a valid reason to think that DS (or any other scan tool) is wrong.
John Estill
