I have a 5 gallon can of Torco 112. Will this be good enough octane for my combo? I am running a TE-44 turbo with 25 psi, 50 lb/hr injectors, and stock untouched motor. The MON of this stuff is 109.5. Should that be sufficient enough? Last time out I ran Torco 116 and the car seemed very laggy and rich off the line. I heard that having too much octane for a given application will slow you down to an extent...is that true? something about the fuel can't ignite fast enough if you have too much octane.
