Racetronix Turbine-Tech Fuel Pump
I don't keep up on all the different in tank pumps. Any advantages vs Walbro 255L?
I just got an email on this, looking for feedback also so... Subscribed!!
Just started shipping these so feedback would be quite limited on this forum. Similar to our RXP340M pump (@255LPH vs. 340LPH) which we have been distributing for two years and is used in our FPS-G7RXP340M/AN.
Understood. Thanks for the reply.
Will these work for E85 applications
In the link I provided it says: use with E85 will reduce life expectancy
Racetronix RXP Turbine-Tech pumps
  • Quieter
  • More resistant to damage from contamination
  • Longer life in Ethanol enhanced fuels
  • Higher bypass pressure
  • Racetronix warranty (Walbro does not offer one)
  • PWM speed control compatible
  • Available in 255 and 340LPH models
Walbro's new 430LPH and 386LPH pumps are both based on turbine not gear-rotor technology as their 255LPH pumps are.
Aeromotive, DW, AEM, etc. all use turbine technology as well.
OK that's good to know.
Any issues using the stock lines with the 340LPH?
